Amp menu on TV
profile.country.FI.title
JuusonK
Amp menu on TV
I have KD-55X85J and STR DN1080 amp. With my previous Sony TV I was able to display the amp menu on TV. With this new Android TV I cannot figure out how to do it.
My amp is connected to HDMI 3(earc). I have disabled CEC in all devices because I am using Harmony remote and it won't work with CEC on.
Any Ideas?
Tagi (2)
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
JuusonK
Figured this out:
Put the Amp in Radio, then from TV select options HDMI3(Earc) and then select menu from AMP and there you are.
1 ODPOWIEDŹ 1
JuusonK
Figured this out:
