Hello all
The aim of this thread is to collate all the issues that are currently outstanding and to provide feedback to everyone in this thread. This thread will be a work in progress and updates on various reported issues will be posted back here on the pages below.
Only issues that can be confirmed by multiple people will be posted here.
NOTE: For anyone experiencing other issues not mentioned here - can you please ensure that you factory reset the TV. Instructions are located: HERE
Update: Due to some TVs that will be on Marshmallow and others that will be on Nougat, this list will be separated into two (ATV1 and ATV2 - see below for model numbers for the difference). If the fault occurs on both versions of Android, it will be listed under both lists.
Current Faults (ATV 1 - Marshmallow):
Current Faults (ATV 2 - Nougat):
Issues Resolved/Closed:
Info Banner - Not changing description from Now to Next
Problem:
When pressing the [i+] button on the remote control, the descripton of whats currently on is displayed. Upon pressing the arrow across to display the NEXT program, the description does not change. Thus far, issue is reported in Greece and Croatia. Issue seems to be from Satellite channels - but not all are affected.
Thread:
https://community.sony.co.uk/t5/android-tv/v3865-info-bar-new-problem/m-p/2322858
Updates:
24-04-2017 - Issue reported to Sony. Any information received will be posted back.
TV Randomly Rebooting
Problem:
Some people have noticed that their TV seems to randomly reboot whilst in use and/or reboot whilst in standby (i.e. overnight. This seems to be happening even more since the Marshmallow update (versions 3.865 and 6.1004).
Thread:
Updates:
13-05-2017 - Issue reported to Sony. Any feedback received will be posted back
Netflix Buffering to 25% then freezing
Problem:
Some people are reporting that Netflix is failing to load since updating the TV's firmware to Marshmallow. The Netflix version 4.0.2 and 4.0.4 is stopping at 25% when loading everything. Upon removing the update and return to the original 3.31 version, it works without problems.
Reported by:
Paolo06Sony - HERE
Malraff - HERE
Updates:
13-05-2017 - Issue reported to Sony. Any feedback received will be passed posted back to the forums.
WiFi will not connect on hidden SSID using 5Ghz band
Problem:
Upon updating to Marshmallow people cannot connect to with WiFi when using a hidden SSID on the 5Ghz frequency. However it does connect using the 2.4Ghz band. This was a previous bug a long time ago HERE, which also got fixed with a firmware update
Reported by:
Quinnicus - Confirmed.
Updates:
13-05-2017 - Issue reported to Sony. Any feedback receivied will be posted back.
[RESOLVED] Customise TV Key greyed out when YouView is enabled
Problem:
With YouView Disabled the 'TV' button on remote control can be programmed to select other sources (Home > Settings > External Inputs > Customise TV Key. However if YouView Enabled = The 'Customise TV Key' is greyed out.
A thread on the YouView forums is HERE. However YouView have stated that this is more than likely a Sony TV issue and not them.
Reported by:
Rockpoolie: HERE
Quinnicus = Confirmed
Updates:
13-05-2017 - Issue has been reported to Sony. Any feedback received will be posted back.
18-05-2017 - Received confirmation from Sony that this is not a bug but "as per design" - there is a mention in the manual HERE
All4 App - TV show restarts from beginning at end of first advert break
Problem:
Upon reaching the first advert break when playing back a TV show within the All4 app, the TV show will restart from the beginning.
Thread:
Updates:
13-05-2017 - Issue reported to Sony. Any feedback received will be reported back.
01-08-2017 - All4 is in the process of updating its app on the YouView platform. It is believed that this issue will be resolved then. ETA of the new version of the All4 app is unknown at this stage.
WiFi - Unable to connect when ethernet cable is connected
Problem:
When and Ethernet cable is connected to an Android based TV, you cannot re-configure the TVs network settings to connect to WiFi instead. Upon physically disconnecting the ethernet cable, then WiFi connects. This was not an issue under Lollipop (Android 5.1).
Note: This does not effect things like casting or screen-mirroring.
Reported by:
Quinnicus HERE
Paolo06Sony HERE
Risc0n - Confirmed.
Updates:
15-05-2017 - Issue has been reported to Sony. Any feedback received will be posted back.
Amazon App - Un-pausing when daydream is activated Issue
Problem:
This problem only occurs when the 'Daydream' screensaver has been activated/enabled in the TV settings - un-pausing in the Amazon app causes the TV to return back to the Android home screen - not resuming the playback of content.
Thread:
https://community.sony.co.uk/t5/android-tv/amazon-prime-app/m-p/2332153
Workarounds:
Updates:
17-05-2017 - Issue has been reported to Sony. Any feedback received will be posted back.
Amazon App - Failing to correctly play first time
Problem:
When launching the Amazon App, upon play video content for the first time it skips foward by a large amount and fails to run properly. After stopping playback and trying again it works fine. This is consistent with SD, HD, UHD content. All videos continue to run ok until exiting the app and the cycle repeats.
Thread:
https://community.sony.co.uk/t5/android-tv/amazon-video-app-55xd8599-first-play-fails/m-p/2335842
Updates:
30-05-2017 - Issue reported to Sony, any updates received will be posted back.
Info Banner - Displays randomly when using HDMI inputs
Problem:
When using a HDMI connected device (i.e. PS4 or Bluray Player), the Information banner seems to randomly display itself
Thread:
https://community.sony.co.uk/t5/android-tv/info-banner-randomly-appearing-with-the-ps4/td-p/2343297/
Reported by:
Jecht_Sin - Thread creator
Educated_Pork - HERE
omegafluxx - HERE
Mike-J-N - HERE
Updates:
26-07-2017 - Issue reported to Sony, any updates received will be posted back.
