can anyone advise if this model should work with bluetooth headphones ?
Thanks for the kudo, @stevie_a123
I just edited the post to add an alternative solution if you can’t get it working the ‘Sony way’, so it may be worth you having another look at it.
https://www.sony.co.uk/electronics/support/articles/00159290
XF80 is not on this list
But explore the options there, and see if they throw any light on the issue.
Or this thread discusses an alternative approach, albeit to a slightly different problem, but the solution could work for you.
thanks apprecitae the responses
