Only get sound out My sky soundbox no sound at all trying watch a movie thru any app or casting in settings audio won’t change to tv audio
How did you connect your soundbox keeping in mind that it is not arc compatible?
Optical cable
And? if you are looking for help I think you should spend more words in order to explain your setup, what you are doing and what you are expecting from your actions...
Sorry unwell at moment will try better next time
i have the same problem and have raised a case with Sony support which is open for the past 3 months.
i have a Sonos Arc connected via an HDMI cable on the eArc port of the TV
sonos arc is OT for problem with Sky soundbox
Did anyone get this resolved
