- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Date/Time stopping internet (Bravia TV KD65-XE7002)
Model: Sony Bravia KD65-XE7002
I've had this tv 3-4 years and all of a sudden it has decided that it doesn't want to give internet access. It will discover the wifi and/or ethernet cable, just not allow internet access. Netflix will work without a problem, Firestick does not.
I have scoured the internet and found that this issue seems to be resolved with the date/time is incorrect compared to internet-based clocks (such as phone, laptop, etc) and that by turning it to manual and then auto, it will fix it. This does not work for me.
When switching to auto the greyed out date/time remains at 01-Jan-2017 and won't switch over, presumably because it isn't getting internet access, even after I have first gone to manually set the date/time to be the same as my wireless laptop and when I've just turned it off and on.
How can I get the internet access to the tv so that it can calibrate to the clock? I have done factory reset at least twice, I have connected wireless and wired. All other devices (wireless or wired) are able to connect to our Sky router and have full internet access with no problem. I have done a hard reset. I have unplugged it and left it off overnight. The firmware is correct and the latest.
I'm pulling my hair out
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @MrMERoberts
You should note that the KD-65XE7002 is a Linux TV and not an Android TV. The chances are that you may get better support in the correct community. Other TVs - Sony
I am not familiar with Firestick, but isn't that an attached device so it connects independently to the internet and does not use the TV's connection? In which case you need to seek help from Firestick (Amazon).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
really? how do you know that?
I presumed with it being a smart tv it was classed as an android tv.
i'll check out that link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @MrMERoberts
Have a look under Software, Operating system: KD-65XE7002 Specifications | Sony UK
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi MrMERoberts, try connecting to a personal hotspot from your phone then change the date and time setting, that probably will do the trick.
