Wellyboots
Explorer
KD-55XE8596
I am getting a message displayed at the top of the tv screen about every three minutes which is very annoying.  I have no idea what it means and we have had the tv from new and it’s only just started doing it.
Any idea why it’s doing it and how to stop it.
thanks
Message that keeps appearing on screenMessage that keeps appearing on screen
3 REPLIES 3
profile.country.IT.title
rooobb
It is the info banner showing that something as changed in the source. If you don't want it disable the banner in the digital tv settings
Wellyboots
Explorer
Thanks for your reply.
do you have any idea where I would find that in the settings menu please.
thanks
Fontmeister
Member
Press the home button -> settings -> channel setup -> uncheck info banner.
