Since my TV updated a few months back i am having issues with my PS4 Pro and 4K HDR setup via HDMI 2. When connected to HDMI2 i can only see the PS4 dashboard if i boot the PS4 into safe mode and select change resolution. I then select Automatic for resolution. If i then go to setup 4K RGB and setup HDR i get no signal message on the TV.
The TV is set to enhanced mode for ports 2/3 so i know it "should" work. If i switch to HDMI 3 and run the same it works without any issues so that rules our a faulty HDMI cable.
Once i get the "no signal" message the only fix is to run through this same scenario again.
The build version of my TV is below
Build: Bravia_ATV2_EU-User 8.0.0 0PR2.170623.027.S32
Any help or any possible way to downgrade the update would be appreciated.
Thanks
By design HDMI 2.0 connections do not have enough bandwidth to manage 4K60fps HDR10 RGB signal if this is what you expect. Has been highligthed in this forum that probably the ARC port (HDMI 3 in your tv) seems to have slightely more than 18gbps to enable those signal. But this is not a feature of HDMI 2.0
T
| 4K | 8 bit | 10 bit | 12 bit | 16 bit |
| /24 Hz /25 Hz /30 Hz |
RGB/4:4:4/ 4:2:2 |
RGB/4:4:4/ 4:2:2 |
RGB/4:4:4/ 4:2:2 |
RGB/4:4:4/ 4:2:2 |
| /50 Hz /60 Hz |
RGB/4:4:4/ 4:2:0/4:2:2 |
4:2:0 | 4:2:0 | 4:2:0 |
Thanks for the reply and info.
i understand where your coming from and I would agree if I hadn’t had this setup working prior to the latest update.
is there any specifications on bandwidth for each HDMI port that you are aware of?
I’ve looked through the manuals and it clearly states the higher end hdr resolution is supported in HDMI 2 and 3 so it should work.
thanks
Thanks for the Info.
oddly I set the PS4 to automatic and it starts up but when I adjust HDR it then stops working.
As you mentioned jumping onto the ARC port allows the additional jump but do find it odd the PS4 doesn’t recognise the correct setting and just work.
if I manually knock the resolution down one it then allows me to configure HDR and it works.
Fair enough, really appreciate the info it’s helped allot.
