on top ofthe problem i am havingwith the connectionto the internet i have another problem when i watch disney+ appletv thru the amazon fire cube the dolby vision picture is very dark then i watch the disney+ app and the netflix app on the tv built in apps the dolby vision picture is still very dark
Hi Stewart,
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
This seems a lot like a software glitch to me. Have you tried updating the TV to the latest software available? I believe it's currently v6.6555.
EDIT: Also try changing the brightness settings around using the Action Menu button once you have something playing (so it affects it directly, instead of a general change) and let us know the outcome of that.
i have latest software v6-6555 i already spoke to sony they are saying there is nothing wrong with the tv the problem is with the apps i tried what you said i changed the brightness to max no change
Have you tried contacting the service provider for any of the apps to see if there are any specific settings that might be causing this?
yes but they refer me back to sony
Can you show us some pictures of both Netflix and Disney+? I also forgot to mention this last time, but have you tried changing the HDR settings using the Action Menu button? I believe there are 2 or 3 options you can pick from.
