KDL-43W805C standby issue
makucg
I have a 43W805C for a few days now and i tried everything to make TV turn off (go to standby) after certain amount of time beeing 'un-active'(not pressing any buttons on remote control) while watching TV. It works with timer but it is quite anoying that i need to set the timer every time i turn the TV on and then if i want to watch some more i need to go to settings again and turn it off or reset it.
Do you have any solutions to this problem?
3 ODPOW. 3
profile.country.GR.title
MiCal1967
Hi
You mean that you select:
Home - Settings - Power - Eco - Power saving (Low or High) - Idle TV standby (preffered period of inactivity)
and this action does not work?
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/23721/kw/eco#2._Timer_settings_
- Try setting of Timers ( On timer and Sleep timer) to OFF.
makucg
I never looked at Eco settings for this...it works now.
Thanks!
MiCal1967
You are welcome
Happy that this works now.
Cheers
