no Red button service KD-55XG8505
Piggy11
Hi all
Yesterday  the Sony KD-55XG8505 had a firmware update, after which i have lost the red button  function on BBC services
thank you all
4 ODPOW. 4
Peter_S.
Genius
Hi,
To my knowledge this is a software limitation.
An information article on support pages should be released soon.
Cheers
Peter
royabrown2
Zawodowiec
@Peter_S.
If it wasn’t a software limitation before the update, how come it’s a software limitation after the update?
My favourite bedtime reading is a Sony product manual…
rickyxsara
I have the same problem. Do you know if there is a fix for it
Joe_Dohn
Specjalista
@royabrown2
I believe that's due to the feature being removed when the BBC decided to change/terminate the service then went back on it with a software update in between those 2 events, which means that the feature may come back in another update.
There was another thread for this same issue, and someone suggested a fix. Might be worth a try @rickyxsara.
- JD
