Question about TV and Soundbar.
SOLVED
profile.country.GR.title
Lazaros_K
Member
I have a KD49XD8305 and am planning to buy a Soundbar. Can I have the TV and Soundbar play simultaneously and not only to have the Soundbar working while the TV is muted?
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
The simple answer is no.
You 'could' have the TV speakers and soundbar working if connect the soundbar to the 3.5mm audio out/headphone jack - if its even possible with the soundbar you are purchasing.  But to be honest, Soundbars are made to use the HDMI-ARC port or Optical 'Toslink'
Cheers
1 REPLY 1
Anonymous
Not applicable
Hi there
Cheers
