good evening
I have a sony 55fx9005 tv bought for 1 month.
I separately bought the touch tx100e remote which went very well on the tv with android 7.
after I made the oreo update, the remote does not work properly.
I only have 2 buttons and now a cursor appears like windows on the computer.
what happened ??
thanks
nobody ???
Well, I just went to 55f9005 until I updated to oreo.
including the microphone.
when I left the left touch on the right, they moved one after the other and the icons scrolled between them.
Now there is a cursor arrow like that of the computer and there are only two buttons.
this is the remote control and has a microphone.
