Request for advice
profile.country.HR.title
Natasa_Mesaric
Request for advice
Hello! The panel on my XR-75X90J TV broke after the warranty expired. The TV was purchased in 2022, it was very expensive and now Sony says I can throw it in the trash. Any advice?
Thanks in advance
1 ODPOWIEDŹ 1
LightFoot
Specjalista
Hi @Natasa_Mesaric   What do you mean by "broke"? If it is physical damage then how about claiming under your house and contents insurance.
