Easy Question, not that I can find an answer, but does anyone know where a description of the button functions on a RMT-TX100D remorte control is.
Cheers
Hi there
Which model TV have you got? The description of the remote control buttons is usually in the reference guide for your TV.
Cheers
thanks, I looked through the user manuals and couldnt find this. Where does it live, the link downloads the PDF so i cant spot it.
Thanks again
Hi there
Search and select your TV model from this link:
http://www.sony.co.uk/support/en/series/prd-tvhc-tv-lcd
And then select the link "view all available manuals"
Cheers
