For those who paid Euro 7.99 and need to watch their movies
Open ES file Explorer
Go to / Device
Go to System (Open folder)
Go to app (open folder)
Find netflix-ninja-release.apk
Select to execute
Select Install
If a message says you cannot install go to Allow Uknown sources and select On
This will give you a message of Update for Netflix.
Just do it and installation will start.
Then everything will work again.
Hello all
As you may be aware, there was some issues yesterday with Netflux after the firmware update. See official article HERE. There are two issues at hand:
Netflix not loading
For many, Netflix was fine, however for others it failed to even load up. This should have 'auto-recovered' itself sometime last night. If it hasnt, can you please try the following:
BT HomeHub
For those experiencing issues and have a BT HomeHub - at the moment you will need to disable 'Parental Controls' and 'BT Protect' in your BT account settings. See support article HERE
Cheers
Hi MiCal1967
Thanks for posting this, but it seems that Sony may have fixed the issue on their end. Its now working on my TV, but i saw reports elsewhere that it was working around the time you posted this
Cheers
@Anonymous
Hi Quinnicus
Yes I thought that too. Could be a ramdom event. Anyway I posted this. Might help someone.
Thanks
Hello all
Netflix not loading
BT HomeHub
Cheers
Tried the solution, it didn't work for me. I am loosing faith with Sony, their android smart is too dumb for most people.
Hi heathfields
What is your exact issue with Netflix? And what have you tried?
Cheers
Can you please reply back with the following:
Also, can you please try rebooting your router too (whilst keeping the tv switched off)
Cheers
Ok, so your baxk to that main issue now, can you try clearing cache etc as mentioned above. Also, check the parental permissions on your bt account too.
