Sony Bravia KD48A9BU HDMI Bravia Sync Problem.
dograha30
HDMI 1 is connected to a Facebook Portal camera, HDMI 2 is connected to a Panasonic DVD Recorder.  When they were first connected both could be operated from the TV remote & a tool bar appeared when pressing I+ including a button to switch on the selected device.  Each device was setup in Bravia Sync External devices (& a picture appeared  briefly to confirm connection).  After a week they suddenly stopped working through the TV remote but still operate normally through their respective remotes.  When checking in Bravia Sync it is now displaying no HDMI devices connected even though they still appear against their designated names.  If they had never worked at all I would have accepted that the devices weren't compatible with Bravia Sync but they worked fine for a week so I'm wondering if there is a fault somewhere.  Any thoughts would be appreciated
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Win_88
Specjalista
@dograha30
Here's what I'd do:
1- Disable Bravia Sync on the TV
2- Disable Control for HDMI (the equivalent feature) on each of the connected devices
3- Unplug all from the mains
4- Reverse step 1
5- Reverse step 2
2 ODPOW. 2
Win_88
Specjalista
@dograha30
Here's what I'd do:
4- Reverse step 1
5- Reverse step 2
dograha30
Many thanks - all working ok now
