Sony KD-55AF9 connecting external active speakers
profile.country.AE.title
khaeid2
Hi all,
I have Genelec active speakers (powered) and I want to use them for audio for my TV.
for now I have two for left and right, but in few weeks I will get the rest, Subwoofer and surround speaker, and they are all powered.
How can I connect them?
There are the normal expensive external AV amplifiers, but they all have passive speakers output.
I found on Amazon few decoders, with optical or HDMI input, and 6 non powered RCA output, which should suit my need, except for some drawbacks, but the reviews for them are not promising.
anyone have a solution for this?
5 ODPOW. 5
Pascale_F
Moderator
Hi khaeid2,
I'll just see if I can find any help regarding this. In the meantime though, maybe another community member might have some ideas.
Thanks,
Pascale
khaeid2
Thank you for answering,
1- I am checking other forums, did not find one good enough yet
2- I used Optical audio output
3- I cannot change level of Optical Audio Output using normal mail volume control
4- I do not have the option of Headphones Fixed/Variant in my TV menu
5- I could access the Headphone menu using Tasker, but had no effect and changed I make there do not stick
6- the only way to change volume is in changing the digital output level. buried under so many clicks to reach it, which is inconvenient.
7- I am trying to access Digital output level page using Tasker, or control it directly by tasker, but I cannot find the correct address to it, or the page name
The_Black_Rose
Specjalista
Hi Khaeid2,
Is there a sound bar or an amplifier connected? I don't think you can connect all of the speakers directly to the TV.
Cheers,
The_Black_Rose
khaeid2
No, not AV receiver nor soundbar,
I am using the Optical output of the TV, connected to a simple decoder Optical/Analogue, it gives me normal RCA analogue output, I connect them to my Genelec speakers who have nternal power amplifier for each speaker, but without level, so I need to connect the output level of the TV Optical output
Win_88
Specjalista
Hi khaeid2,
Have you looked at any of the amplifiers made by Sony as an option? Maybe something like this:
https://www.sony.co.uk/electronics/support/audio-components-receivers-amplifiers/str-dn1080
Win_88
