maybe someone faced with such a problem? White spots on the screen (glow)?
Hi there
I think what you are referring to is commonly known as 'clouding' or backlight uniformity. Unfortunately this is common in LCD technology. But some panels are better than others.
Have a read:
http://www.rtings.com/tv/tests/movies/dark-scene/black-uniformity-clouding-flashlighting
If its bad (and only you are the judge of that), contact your retailer and ask for a TV exchange.
Cheers
