I need to know the distance between the bottom screw holes in the back of the TV in to which the wall bracket is attached to the actual bottom of the TV on the 48" OLED??
Have you tried using a different cable or a different HDMI port? Seems like the Sky box is the culprit if it's the only one causing the issue.
My pleasure ^^
Hi Joe My KE48A9 is proudly installed with a wall bracket. Could I ask another question. I have a HDMI lead connecting my SkyQ box. When I switch on the TV and my SkyQ box the TV shows the Sky screen then clicks off to a blank screen
repeatedly for 3 or 4 times before showing to view. Is this normal?? Is there a preferred HDMI input (I also have a DVD player connected but this is seldom used)
Glad to hear that!
As for the other question, does it click off using the DVD player as well or is it only the Sky box?
- JD
