Hi, I have a new Sony Bravia TV model number KD43X8309 CBU and I cannot do a software update. I get the message "Update server temporarily unavailable - try later (error 2123)" I have tried this at all times of day and night with the same message which occurs when the update is 72% complete (every time)
Can you help?
Regards
Mike Manning
Hello Quinnicus
Your solution worked perfectly and I upgraded the firmware via a memory stick. Thank you very much, the TV is far better now.
Regards
Mike
Hi there
I have sent you a private message with some instructions. Let me know how you get on.
Cheers
Im having the same probelem, can you help
Regards
Daryll
