- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello, everyone! I struggle recently with this feature and I am not sure if it is available as mentioned in several Sony Android Tv documentations. I am trying to project Windows 10 PC to the specified Android Tv and when I press Inputs button there is no Screen Mirroring option, there is no such application installed and I can't find it in Google Play Store. Do I want too much, I know about the alternatives - there is AirPlay installed, but I do not have payed AirParrot account and I find it disturbing to actually need anything from Apple while having Android Tv. Not to mention that there are definitely connectivity issues when I try to connect it automatically from Wi-Fi Direct menu. What options do I have?
Best regards!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Miracast is not supported anymore, you can still use google cast that is quite easy on android device but is possible using chrome also on a windows pc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My preferred option is a HDMI cable from the PC to the TV.
Surely your TV has Chromecast built in? Settings/Network & Accessories/GoogleCast. Maybe the ScreenMirroring Source option appears only after first use? Is your TV discovered by casting apps on other android devices?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello! Chrome cast works great, I tried it, but I needed to have things outside Google Chrome, like other players and applications, just the way AirPlay and ApowerMirror both work great and I see all content from PC. At least you gave me clarity, I will need either one of these applications or will use HDMI. Thanks for the information and the replies, everyone!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Found "Cast desktop" and the quality is great, thank you very much for this!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
One plus with the HDMI cable option is that you can control the PC from the TV sofa with a RF mouse (or a RF remote or RF keyboard) with the RF receiver in a USB port of the PC. From my RF mouse to the RF receiver it is about 3-4 meters and in between there is my body and a wall to pass. Works fine!
