UKTV download
DavidD48
UKTV download
I have the KD48A9 tv and am very pleased with  the product
My issue is that I can’t get the UKTV app or catch up via YouView any help would be appreciated
5 ODPOW. 5
royabrown2
Zawodowiec
@DavidD48
You have to connect it to the internet for these things to work. Have you done that?
My favourite bedtime reading is a Sony product manual…
DavidD48
Yes I’ve got lots of apps working such as BBCiplayer and ITV Hub but can’t find anywhere to download UKTV
Thank you for your prompt reply
royabrown2
Zawodowiec
@DavidD48
Have you looked in the Google Play Android TV store?
As yours is a 2020 TV, it should be there for you, though earlier models won’t be able to access it.
DavidD48
Thanks for your reply I have searched on google play but can’t see it to download looking at old posts people suggest downloading kodi so may have to try that if I can’t get it anywhere else
Thanks for your help
room_101
