Unable to Update my Bravia Tv Model Kd-55x8505c
Ahmed14shukri
Everytime i tried to update my tv Kd-55x8505c to the newer version the Tv display error "2123" using the lan network so i tried to do update it via usb today and it also failed "once the Tv read the Usb it turn off and back on with no response" i check the comunity for solutions and did two copies of the update but still the Tv didnot respond!!
the current version of my Tv is PKG2.287.001EUB
5 ODPOW. 5
Risc0n
Ahmed14shukri
I'll try it
thanx
Ahmed14shukri
i'm still not able to update my TV .the Same error "2123"...
Anonymous
Nie dotyczy
Hi
Does it cut off after a certain percentage?
Cheers
Ahmed14shukri
No it cuts off from the start
as soon as the progress bar apears "after inserting the USB" it last for less than few seconds then the TV resets with no change in firmware...
