Hi there. I noticed that after the latest update of my TV with ν112.631.085.1 Steam Link App doesn't work at all. Disconnects right after it tries to connect. I tried deleting and relinking the PC and TV. But no fix there. I also tried and factory reset my TV. Same luck. I also noticed YouTube app is freezing from time to time. All in all the worst update i had for this TV. Broke many things.. Does anyone have such issues? Or knows how can they be solved?
Hey @Celphius ,
- You can this as a work around:
- If it works you can do this to other effected Apps.
Have already tried this. Nothing works
@Celphius In that case I believe you need to report that issue to the technical team in Sony: https://services.sony.co.uk/supportmvc/en/contact/https://services.sony.co.uk/supportmvc/en/contact/
