Solved! Go to Solution.
Hi @Ebscorpion,
The pre-installed Messaging app do not have a feature that allows you to block incoming messages. However, if you are using Hangouts for SMS/MMS you can block messages from specific numbers or contacts. You can read more about how that works here. I believe that Google's dedicated SMS/MMS app Messenger also has this feature.
Other than these alternatives you would have to look at third party alternatives. You can check the link that Alexdon provided for more information.
You should read this:
/t5/Xperia-Z1-Z1s/How-to-block-someones-call-and-sms-on-ma-xperia-z1/m-p/750679#M29478
Hi @Ebscorpion,
You're welcome.
