отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Mobile data disabling itself, sleep setting changes
РЕШЕНО
kristal17
Посетитель
Hi, I recently got hold of a C1905 and love it, apart from two fairly important faults.
The Sleep/inactivity setting keeps changing from my preference of 5 minutes to 15 seconds.
Also, the Mobile Data option keeps disabling itself.
Is there a setting to prevent this from happening?
Or it is this a bug with the hardware/firmware?
Any help would be greatly appreciated as it starting to drive me crazy.
Many thanks,
Kris
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
profile.country.RO.title
_alexdon_
Do you have stamina mode enabled? If yes,the option will disable mobile data.
alexdon
Просмотреть решение в исходном сообщении
10 ОТВЕТ 10
_alexdon_
alexdon
Hampus
Чемпион
Hi,
Regarding the screen it may have to do with the setting "Low battery mode" via Settings > Power management > Low battery mode > Screen timeout. Check if this one is set to 15 seconds.
kristal17
Посетитель
I did have stamina mode enabled. Thank you! Would this apply to the screen time out as well?
kristal17
Посетитель
Hampus, it is set to Adapt to Device Settings at present.
_alexdon_
But is low battery mode enabled as Hampus stated?
alexdon
kristal17
Посетитель
Apologies Alexdon. Low battery mode was enabled. Will disabling it prevent the 15 seconds screen Timeout?
_alexdon_
If you disable it,you can extend the timeout.
alexdon
kristal17
Посетитель
You guys are the stars, you've made my week. Thank you.
_alexdon_
Anytime.
alexdon
