No display
reizer0
No display
My device have no display yet it still working...
it is working because it is still charging and when I connecting in my laptop using pc companion, they still detected and can be explore the files.
Tagi (2)
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
reizer0
Soft reset is the solution, im checked the manual how to deal with it and it work. Thanks for the help.
5 ODPOW. 5
Uliwooly
Repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Uliwooly
If PCC doesn't work then contact your local Xperia Care
http://www.sonymobile.com/global-en/support/contact-us/
Hi reizer0,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You could also try performing a soft reset on the device, this could just be a small glitch.
Hold power key and Volume Up key for 10 seconds. Once the handset vibrates 3 times leave it for 10 seconds then try power the device.
let us know how you get on either way.
reizer0
Uliwooly
Anytime
