problem with internal device memory
kunal_kv
I am getting problem with internal device memory in my sony xperia c. I am pissed of with limited storage to install apps!! Help me to clear internal storage or to uninstall unused apps which came as default!! ASAP
Tagi (1)
92 ODPOW. 92
Lucky_Raj
hi to all, I m facing the same problem, plz tell me how to transfer installed apps from device memory to sd memory without losing the phones warranty or any other changes that violates the Sony rules
secondly when device memory is full the phone doesn't turned on after switched it off.
and lastly y camera button doesn't work every time
Joshaeliton
we are all facing the same problem,,SONY doesn't giveus SOLUTION!!!!
SONY SHOULD RELPLACE OUR PHONE THAT'S THE BETTER SOLUTION...THERE IS A DEFECT TO THEIR PRODUCT AND YET THEY ARE NOT DOING ANYTHING..
I SHOULD HAVE BOUGHT IPHONE OR SAMSUNG INSTEAD!!!!
dannysteele
How do I save apps to my SD card to free up space
SahS4
sony xperia **bleep** sorry. I still prefer my Samsung S
3 mini over this
Saivarma
Preloaded apps like movies, office suite, Google play store are occupying a lot of internal memory and cannot be moved to external memory.
There is no such option to move for preploaded apps.
PHDC
Until now, Sony has never respone to the existing customers & users to the problem.
Perhaps the best solution for all sony users are to boycott sony forever. start publish all the problems & customers good respone culture to public.
kiranmalwe
Worth to buy this. You can only install 2 or 3. More app. And it's full then. I love sony but this is worth
RY_6381
Hi Friends...It seems SONY has left us with no option to solve the Low memory problem, but there are certain tips which can help:
1. Install APP2SD app and move all possible apps & games to SD card like the ASPHALT8..
2. Set the default storage to SD card in the settings and as well as camera settings. Restart the phone so that the changes are saved, to confirm the same once phone restarts, you will find notification confirming on the change in default storage location.
3.Disable all the preloaded Apps like Google Plus, Line,Evernote, etc which are not used, these apps take frequent updates and eat up the memory space. Disabling helps prevent this apps to take updates.
4.Install app like 360 secure which will help free up memory and RAM frequently improving the performance.
Hope this works out  to some extent, although its not a permanent solution...
pullur
what should i do to get out to this problem
gjdzv
esh) PERMALINK
When ever i am downloading from play store,its showing error as insufficient space on your drive.But ther is a lot of free space in my phone and device memory..so what to do to solve this problem..i already disabled the playstore then enabled again and i cleared the cache too..so please help me out..Thank You..!!
