- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My new Xperia C shuts down upon receiving call. I can hear one ring and the phone goes off. I have to restart it manually. It doesn't happen with every call but once or twice a day. I really hope Sony offers some solution.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do you have some task killers,antivirus?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes.. it has an antivirus installed. Is that a problem? Should I remove it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I suggest you remove any kind of apps like:antivirus,battery savers,task killers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks. Will try. Local service centre has also suggested a software upgrade. Will get it done over weekend.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Gave it to local service centre. At first they took it for just software update. Then they found certain parts also needed to be changed. So it was done and phone delivered after four days. I noticed they got rid of antivirus too but did not tell me anything about not installing it again. So I don't know whether I should or not. Anyway, it has been four days and the phone is working fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well,at least now it is fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Set the first SIM on WCDMA and the second on GSM only.
