cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Transformar Handycam em webcam
SOLUCIONADO
profile.country.pt_PT.title
Noddy-coroas
Visitante
Boa tarde,
Comprei uma HandyCam HDR-PJ200E, e gostava de saber se a posso usar também como webcam para poder usar em chats, uma vez que a qualidade de imagem é muito superior á minha webcam. Tenho de instalar algum software especifico? Alguém me pode dar uma ajudinha. Obrigado
1 SOLUÇÃO ACEITE
Soluções aceites
V57...
Participante
Caro Noddy-coroas,
Bem-vindo ao forum da Sony...
Penso que isto poderá ajudar...
How to use a Sony® camcorder as a webcam using USB Streaming.
Solution
IMPORTANT:
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
Cumprimentos
Ver solução na publicação original
3 RESPOSTAS 3
V57...
Participante
Caro Noddy-coroas,
Solution
IMPORTANT:
Cumprimentos
bjrcarlos
Novo
Olá, Bom dia!
Eu comprei uma Handycam HDR-CX 220 e gostaria de utilizá-la como webcam para fazer transmissões ao vivo pelo Youtube. Mas o computador não a reconhece como webcam. Gostaria de saber se esse modelo tem essa função e como eu faço para configurá-la.
Att,
Carlos
profile.country.PT.title
BlueZee
Entusiasta
Parece que pode se tiver opção para desligar a poupança de energia:
https://us.en.kb.sony.com/app/answers/detail/a_id/37732
Desactivar a poupança de energia (em Inglês):
http://docs.esupport.sony.com/dvimag/HDR-CX220_CX230_CX280_CX290_CX320_CX380_CX390_HDR-PJ220_PJ230_P...
Espero que resulte.
Algumas vezes o alfabeto começa pelo Z...
