Remote For HDR-CX240E
SOLVED
outjohn9
Explorer
Hi
Does anyone know if there is a third party or Sony remote - ideally IR but wired would be OK - for the HDR-CX240E camcorder.
With thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
I believe these are compatible with your HDR-CX240E
From the US Support Site:
https://us.en.kb.sony.com/app/answers/detail/a_id/44092/~/which-cameras-are-compatible-with-the-rm-v...
Page 21 and 22 of the manual : HERE describe how you can use your Smart Phone to remotely operate the camcorder
However I strongly advise you to contact Sony's Sales line: HERE to confirm compatibility before purchasing.  Better to be safe and double check, as this is as much as my Googling can get :slight_smile:
Cheers
2 REPLIES 2
Anonymous
Not applicable
Hi there
Cheers
outjohn9
Explorer
OK many thanks for that info.
