Application menu taking time to load
Koushikan
I have been using this device since July. Recently I have been noticing that the application menu (one through which we are able to open app,on the homescreen) is taking some time to load. What could be the possible reasons?. I have 2.8 gb of free space in my internal storage and SDcard (each).Suggest.
14 ODPOW. 14
Koushikan
Same problem continues.but better than before. Wat do I do know?.only very necessary third party apps have been installed now in my device. Default Antivirus app used.no other extra cleaner /booster used.
Koushikan
4often I get the message "Xperia Lounge is not working. Do you want to stop it".could that be the culprit app?
xperiaperson
Anything is possible at this point. I keep it disabled. Try also if you have no use for the app.
If nothing else works a repair through PC Companion could solve the issue.
Koushikan
Software repair through Pc Companion did the trick
xperiaperson
Excellent Slightly_smiling_Face
