Call block
sribala
Call block
Hi Sony Team,
May i know how to block the particular caller.
Thanks,
7 ODPOW. 7
Rickard
Guru
If you save the number as a contact in the phonebook and then edit the contact you have a checkbox at the bottom for "Send calls directly to voicemail". Enable this to block calls from the number.
Rameesh
Hi Sony Team,
How to Unblock phone number
how to go to the restricted list
profile.country.RO.title
_alexdon_
There is no option to block. How did you block someone?
alexdon
Drj
Yea,you can block the call for paritcular numbers by following these simple steps.
Suppose you want to block a number <9876543210>
If <9876543210> is already saved in your contacts under any name storing multiple phone no.
      1. First remove <9876543210> from there.
      2. Create new contact with <9876543210> under a different name ,say<xyz>.
      3. Go to menu which is at the top right corner,there you will get a checkbox for "All calls to voicemail",mark that checkbox.
      4. Click <Done>.
If <9876543210> is already saved in your contacts under any name <abc> storing single phone no  <9876543210>.
     1.Edit  <xyz> in your contacts.
     2. Go to menu which is at the top right corner,there you will get a checkbox for "All calls to voicemail",mark that checkbox.
      3. Click <Done>.
someshswararao
Call Blocking
Block Calls from a Phone Number:
  1. From the home screen, tap "Apps"
  2. Open the "Contacts" app
  3. Tap the contact you wish to block
  4. Tap the "Edit" icon and then press "Menu"
  5. Mark the check box associated with "All Calls to Voicemail" and you're all set
littleMai
what if i dont wish to receive voicemailfrom this contact
Miila_Mahe_Aed_
Since the topic has so many views:
Go to "Play Store" and install "Calls Blacklist".
Then you can block anything.
Have a nice day
