When I go to 'add > widget' it pop ups: 'Unfortunately, widgets has stopped.'
I have Xperia E (C1505).
uninstall it > restart your phone > check again
What if you restart your phone ?
Do you have a taskiller or task manager or antivirus?
I knew it
Just wanted to say that I had the same problem and for what I read on other blogs I thought it was Google Maps update, but your solution was the one that made the trick! Thank you so much!
