Hi @Belle1737, let me see if I can help out here.
There is no pre-installed function in Xperia E5 enabling you to block a specific number from calling you. However, if your subscription includes a voicemail service, you can send all incoming calls from a specific contact directly to voicemail. To do this, Add the number as a contact > Open the contact > Tap the pen icon to edit the contact > Tap the menu icon (three vertical dots) in the top right corner > tick the box next to the text "All calls to voicemail".
I hope that helped! Let me know if you have any further questions!
Can you please block this number hidden as it keeps ring me and I don't want them to have my number so can you please block it
I am afraid that it is not possible for me to block a number on your phone from a distance, but if you follow the instructions in my previous post, all calls from that number will be directed directly to your voicemail.
