I'm having the same probem with my E5, its super annoying that i have to keep putting it on speaker phone and/or restarting my phone, as not a situations are ideal for this.... no settings to change anything related... how can I get it fixed?
Hi can anyone help me please! I've lost the date and time from my homepage and can't seem to get it back. Would really appreciate it if anyone could help xx
I had the same problem with my microphone and I disabled my 'ok google' now people can hear me when they phone me thank you was driving me mad.
Try turning off your 'ok google' you will find it in settings then go to lock screen & security,then go to smart lock & then enter your password that you have like pin or pattern etc, then go to trusted voice click on it then turn off 'ok google'
Hope this helps
Emma x
Um lixo me arrependi da compra
Ja esta com defeito no microfone
Foi para assistencia e continua o mesmo defeito e vou ter q mandar
A piece of junk I regretted buying
Is already defective in the microphone
It was for assistance and continues the same defect and I will have to send
GT
Hi there. I'm experiencing the same problem with my phone. Only had it in May as an upgrade would you believe. Within a month the speaker went. Contacted my provider as paying for the phone monthly. Was told to do a factory reset which I did. It worked for a couple of weeks then went again. This has happened 3 times now and they want me to send it back to be repaired. Given the fact it's not fit for purpose and that they say it could take a week or two to repair thus leaving me without a phone as I have to return it to them, I am visiting the store in the next few days for a refund. By the way the Bluetooth link for the car only worked for an hour before that stopped working as well. Never had these problems with my blackberry!!!!!
I also have the same problem of noo e hearing me on calls and turning phone on and off constantly pease help as very frustrating
i got my e5 in may this year sent of to repair mircophone 3 times now and its still doing the same thing on calls were no one call hear me on a call
