Hello,
I have been using Xperia E Dual for the past six weeks. When I receive an SMS, it doesn't alert me with sound. I became aware of this only two weeks ago, but the problem may have started well before that since I am not a heavy user. I initially had ICS when I became aware of the problem, but the problem remains even after I upgraded to Jelly Bean 4.1.1 last week. The phone rings with sound and the alarm is audible - no problem there. I played with various settings but nothing seems to remedy the problem. Is there anything particular I may have overlooked?
Thank you for any suggestion you might make.
rpm0759
Have you checked Messages > [Menu] > Settings > Notification?
Also check Settings > Sound > Notification.
The first one overrides the other one, in order to enable usage of different tones for standard notifications and SMS/message notifications.
What are your thoughts about this forum? Let us know by doing this short survey.
Dear Samuel,
Thank you for the reply.
The second setting had some tone turned on but, as you indicated, the first setting overrode the second one. I have now selected some tone in the first setting (which was set to 'none' previously) and everything is fine now.
Thanks once again for your help.
rpm0750
I'm glad to hear! Let me know if there is anything else I can assist you with.
Dear Samuel,
I also have the same problem. But, in my case 3 days ago the alert of notification and SMS is worked well, and suddenly the alert for SMS doesn't work. It's just vibrating. I've tried to do the setting above but it still doesn't work. How can I do to fix this problem? Really need your help.
Thanks.
