it makes a strange noice like interference and then it turns off. After a few seconds it turns on again, all of this by itself without me doing or touching anything.
And this have been happening since December 1st, Chronology: December 1st at 21:20, December 2nd at 22:20, and December 3rd (today) at 21:48
Hi @Kyubi8,
I'm sorry to hear this.
I recommend that you restart your device to safe mode to see if this behavior is caused by one of your downloaded apps as these will be temporarily disabled in this mode.
If you are still experiencing the same behavior I'd recommend that you temporarily remove any SIM and SD card from your device to see if they may be the cause of this behavior.
Keep me posted on how it goes.
