Epub font huge
profile.country.en_GB.title
bobbyger
Visitor
Epub font huge
I have downloaded a book from kobo. however, when I try to read it the font is massive even when the ereader is set to xs. It takes around 10 to 12 page turns to read 1 page on the book. does anyone else have this issue and have they found a workaround.
Cheers
7 REPLIES 7
carpetmojo
Member
x50's or T1 ?
bobbyger
Visitor
Not sure what you mean by x50 or T1 but my ereader is the prs-350
carpetmojo
Member
Hello bobby - x50's = 350 and 650 generation, T1 is the next .
Your 350 should be OK with the Kobo books - but only epub and PDF .
Kobo do sell some books that won't work on the Sony, it may be (bit unlikely, as you d/loaded it) that the problem lurks there. Or it may be a dodgy version.
I see you have played around with sizing etc..
Other than that, try a soft reset, it may wake things up.
Or, contact Support.....
Haven't heard of this before - is it OK with other new d/loads ?
Otherwise, if you have the download intact, you could delete from device & try it with Calibre ?
bobbyger
Visitor
Hi carbetmojo,
thanks for the info. I have tried to read it using the reader library and it is the same, I will try Calibre and see how it goes with that.
All my other books are fine, just that one.
carpetmojo
Member
Does sound like the format or related  - good luck.
carpetmojo
Member
Sorry bobby - could try, if it's not too £££$$$'s, getting it from another source ?  If that one's OK, it's Kobo.
carpetmojo
Member
Bobby  -  see your PM'S... Hope it helps.  carpetmojo
