Digital Camera Model DSC W830
sheilakjones
This model does not appear on the list & therefore I am unable to complete the registration form
3 ODPOW. 3
Tenneen9000
Hi sheilakjones,
You'll have to enter the model number in its correct fashion, which is DSC-W830. Alternatively, you can press on " Can't find your product? Search by category." and select your camera from the list.
Cheers,
Tenneen9000
sheilakjones
I have done this already. No use.
profile.country.IT.title
Marino.Manolo
Genius
In Italy it is possible to record this model, there should also be the possibility in the United Kingdom, I imagine the database is the same.
Manolo
