STR-ZA1100ES Needs Power Cycle
profile.country.US.title
hasbeen
Member
My STR-ZA1100ES receiver seems to freeze inside sometimes. It won't pass audio from my Sony Bravia TV and when I with to other HDMI inputs connected to the devices it doesn't show on the TV either.
If I unplug and plug back in after a minute everything returns to proper behavior.  Anyone else?
Latest software installed
3 REPLIES 3
Elodin
Moderator
Hi, you can try checking the steps in this link, if that didn't fix the issue, you'll need to reset the receiver to factory settings from this link. I hope this helps
hasbeen
Member
Thanks for the tip!
Elodin
Moderator
You're always welcome man, we are all here trying to assist each other.
