Comparte tu experiencia!
Hello!
I have a problem where when I turn my TV on, the sound system only works about half of the time (even when it says TV on the unit). If it doesn't work, I can switch input (on the TV), and that will sometimes fix it. Otherwise, I have to go into the home menu and manually switch back to TV.
My girlfriend is getting ***** off at this.
Is there a way to not have my Samsung TV remote turn on the sound system or set it so the tv always just uses the tv speakers? I would rather have to manually engage the speakers when I want to watch TV with surround than have the girlfriend get mad at me.
Thanks!
¡Resuelto! Ir a solución.
Hi there
Disable 'Control for HDMI' in the HDMI Settings, in the System Settings menu. This will prevent the TV from turning on the BDV-N7200W
Cheers
