Hello I have noticed and a lot of others have mentioned that the Bravia 8 II has noticable colour banding and has worse gradients than the A95L. Vincent, KG, Classy and judges at the VE shootout yesterday + many other normal consumers have all mentioned this also.
The S95F uses the same panel and doesn't have this problem
Can this please be fixed in a firmware update?
@Sony123678 wrote:Can this please be fixed in a firmware update?
Hi @Sony123678 I am sure it could, but only if you make Sony aware of your issue. This is a customer helps customer community. Sony Support.
