Home Thearte DAV-SB200 Side speakers not working in Video mode
Hello, recently i hooked up my DAV-SB200 to PC via 3.5mm jack to red/white audio, everything seems to work good except the side speakers, they have muffled low (very low) volume in them but again if i swap to dvd mode, all of them work perfectly, any ideas how to utilise all 5.1 not just the rear speakers / front speaker / and woofer? Thank you in advance!
2 REPLIES 2
cass_n
Hi @AegisTitan,
I'm just looking into this and will come back to you shortly (unless another community member is able to help you in the mean time of course!).
Cheers,
C
cass_n
Hi again @AegisTitan,
I checked this with one of our product experts for you and have the following info to share:
"There is a control on this model marked AFD, simply toggle the button until you select a ‘Prologic II’ mode (usually music).  This will then allow you to make use of all the loudspeakers in the system, when playing back a two channel music source."
I hope this is helpful?
C
