whenever type sumthing ther is li'l lag b/w the press and the display
i have tried with viberation on and off but problem remain what to do ?
I'd recommend switching keyboards. You can download the stock google keyboard from the playstore, it feels way more snappy than the Xperia keyboard. (If it doesn't show up for you, it's because the app is region restricted, look here for details and download: http://www.androidpolice.com/2013/06/05/new-app-google-adds-stock-android-keyboard-to-google-play-fo... )
Edit: I switched because I was used to Google's keyboard and I ran into lag problems with stock Xperia keyboard when I used spellcheck/autocorrect for two languages. It's not a good fix if you like the Xperia keyboard, but you could at least try if it is faster for you.
try to delete all your sms/mms and call logs > restart your phone
also uninstall intrusive unnecessary apps
taskillers
task managers
antivirus
battery apps
ram apps
booster apps
i have done that but nothing happens much keyboard still lags
also subway surfer and pitfal game lags, ol other games like real football real racing csr racing works fine
games and other apps its up to the developer to fix this bugs not Sony. as for the keyboard, that seems quite odd, repair your phone with SUS or PCC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
i have done this also man but nuthing happens problem presist
