notification means?
SOLVED
kurzesolino
Visitor
notification means?
I need help What does it means (like Timer or chronometer near the signal strength)
1 ACCEPTED SOLUTION
Accepted Solutions
ashwin21
Visitor
thats the Low battery mode..By default, it activates when Battery status is below 30%.
You can check it out at Settings>Power Management>Low Battery Mode.
1 REPLY 1
ashwin21
Visitor
