since I upgraded the android verssion of my sony xperia l to 4.2.2 it stopped downloading or apdating apps
now I used my computer to upgrade the system 15.3.A.1.12
the same problem still exists
I don't know what to do
Solved! Go to Solution.
You have download manager app,try force close,clear data and cache.
Download manager can be found in settings-apps-all.See how it goes.
What do you mean by it stopped downloading?Where are you trying to download from?
from google play
It wouldn't even update the built in apps
Try to clear data for google play in settings-apps-all,force stop and start again.
ok did that and restarted the device and now I'm trying to download an app and see what will happen
but in case the problem presisted should I uninstall the updates of the google play app
please nots that in order to update the android software I used my computer pecause the device does not download any thing
so I think the problem is not the google play app
it's the download mannager itself
Yes,you could try removing updates for google play,or another option could be reinstalling current software with sony update service.
ok will try that
I don't know how to remove the updates of the download mannager though I can't find it in the app list
thank you
you are very helpful indeed
Nothing new unfortunately
I think I'll restore the device to factory settings and never update the android again
thanks
You are welcome,sorry for your issues...
