Sound problem
mhmtymn
Sound problem
İhave used xperia L for 2 months. Although volume degree continuous full, sometimes (especially after missed call) phone volume up down and volume degree still show maximum. after I restart my phone this problem is solved. What should I do?
40 ODPOW. 40
profile.country.RO.title
_alexdon_
Have you tried a software repair until now?Because I told you before but you did not tell me if you repaired.
alexdon
mhmtymn
I trıed but ıt is contınue
_alexdon_
Just visit a sony service.
alexdon
Olsialb
I also have this problem Slightly_frowning_Face Sony Support does not help for this problem than what to do.
Why?
_alexdon_
hornbill
Try the following:
1) Go to Tools (setting) - > “Xperia”  >“Internet Settings”  click ACCEPT  to install the Internet & MMS setting.
2) After update, Manually Switch off and On the phone.
Soli
me too have this annoying probelm, kindly if anybody could solve it , tell us
RaduThor
Me to, I have the same problem. I try to reset at the factory setings twice, format the memory card, and phone memory, after a while the problem is back. In this moment I give him this software repair... will se after.
RaduThor
Ok, from now(couple of hour since) the problem was solved with "update service". Will see, last time past factory reset, and format all, the problem stay's away about a week.
_alexdon_
Keep us updated.
alexdon
