Xperia L1 lost icons
SteveN8458
I've had this phone for a few years, and it does all I need.
Please be patient with me, I find mobile phone setup difficult!!
However I have recently noticed an app icon has disappeared.
If I go into settings/apps, the app is listed.
So how do I get the icon back to the home screen??
When I searched online I found the manual and in that it said to tap on the APP icon (2 rows of 3 dots), but this icon is also missing!!
And to all those thinking, it could be the user! they are probably right :slight_smile:
Thanks
Steve
13 ODPOW. 13
profile.country.IT.title
Marino.Manolo
Genius
Enable swipe-up (on), switch off...
SteveN8458
Progress :slight_smile:
By swiping UP on the home/app screen I was able to fine the icon for the missing app.
By holding the icon across the top of the screen appeared 'add to home screen' which I did.
But I am still missing the APP (6 dots) icon missing.
Marino.Manolo
Genius
Ok, but, if you have swipe-up ON you don't see the Icon (6 dots), disabile swipe-up (OFF) and Icon (6 dots) appear...
SteveN8458
Thank you.
That worked.
Many thanks for you patience :slight_smile:
Steve
