Does M5 have VoLTE Support?
Pra123-
Does Sony M5 support volte and what is the benefit of volte.
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Emir1
Zawodowiec
Hello everyone, I have received some additional information regarding the VoLTE feature. I am sorry to say that our Sony Xperia M5 model does not support VoLTE, according to the information that I have available. However, I would thank you all for the shown interest in such a feature and I will make sure to forward it internally as user feedback!
37 ODPOW. 37
Emir1
Zawodowiec
Hi @Pra123-,
I recommend that you get in touch with your operator regarding this feature, since it is dependant on the operator. Contact them and see if they have plans to launch the feature for your device.
An example of the benefits using VoLTE is being able to make high quality phone calls over LTE (4G) rather than 3G.
Ksharma
Is xperia M5 support Voice over LTE. How can it activated im M5
profile.country.PH.title
MarlonUk1
this a network dependent feature, so it would be better to get in touch with your network provider on how to activate it
Ksharma
Please give voice on LTE (VoLTE) software update on Xperia M5 dual.
Emir1
Zawodowiec
Hi @Keshav2,
This feature is dependant on the operator, therefore I recommend that you get in touch with them to see if they plan on rolling that feature for your specific phone model. Slightly_smiling_Face
Ksharma
I already have mobile number with VoLTE, but my phone does not support it.
Pravin123
Hi my Xperia m5 not support volte but same sim support in other brand phone they support volte means it's not on operator it's on ur device support
Epicurean
VoLTE comes with the operator branded firmware, and will be more or less limited to that one operator (you can be lucky, but more often you will not be).
Emir1
Zawodowiec
Hi @Pravin123 and @Keshav2,
Just to clarify what I meant, the operator has to enable the feature for your specific device - this is not dependant on the SIM. My recommendation is that you get in touch with your specific operator to see if they plan to enable VoLTE for your specific device and their operator branding.
I hope that clears things up! Slightly_smiling_Face
